E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Help choosing power
Reply
Old 11-01-2014, 07:12 AM
Guitarman52
Guitarman52's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help choosing power
I am new to electric flight. I purchased an eflite 60 size motor for the below plane. The motor is too long. Is this too much motor for this plane or would you recommend something smaller. I have a 80 size esc for it.
http://www.rcjetsworld.com/index.php...-50e-3d-detail
Guitarman52 is offline
Old 11-01-2014, 09:45 AM
Quorneng
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guitarman52
The Eflite 60 is recommended for planes in the 6 to 12 lbs range. The Sbach342 50E 3D is in the 4.6 to 5.3 ibs range so it is not that surprising that the motor does not easily fit.
For 'new to electric' you do seem to have jumped right in!
Personally I would have recommended something a bit more modest to get some experience with electric power set ups.
Quorneng is offline
Old 11-01-2014, 10:01 AM
Guitarman52
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I guess I should have qualified new. I have been flying for 6 years, including a few electrics that were already with the planes I bought. This is my first plane that I bought the motor and esc separate. I appreciate your comment but you really didn't answer my question.
Old 11-07-2014, 02:57 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This will be a helpful resource:
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
http://www.rcuniverse.com/forum/m_7100376/tm.htm
But beyond that there is always the matter of looking at the size specs for the motor and the space in the plane to see if the motor will fit. Not really different from anything else.
So, clearly you NEED a smaller motor since the one you have does not fit. That is obvious.
As you will read in the chapter on sizing your plane you size by watts/pound. The weight of your plane is roughly 5.3 pounds. So you will want a motor rated at 400 to 800 watts depending on what kind of performance you want.
Looks like they are recommending a 14" prop so we know that will fit the plane with required ground clearance.
We could run one of the calculators:
http://www.electrifly.com/powersyste...tem-index.html
Assuming a 4S pack:
Motor Recommendations
[TABLE]
[TR]
[TH][/TH]
[TH]Best Speed Setup
[/TH]
[TH]Best Thrust Setup
[/TH]
[TH]Best Combination
[/TH]
[TH][/TH]
[/TR]
[TR]
[TD="align: right"]Performance
[/TD]
[TD="colspan: 3, align: center"]Sport
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Motor
[/TD]
[TD]42-40-1000 / GPMG4675
[/TD]
[TD]42-50-600 / GPMG4695
[/TD]
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Gear Ratio
[/TD]
[TD]N/A
[/TD]
[TD]N/A
[/TD]
[TD]N/A
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Gear Drive
[/TD]
[TD]Not Required
[/TD]
[TD]Not Required
[/TD]
[TD]Not Required
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Propeller
[/TD]
[TD]10x5 in., Electric
[/TD]
[TD]14x10 in., Electric
[/TD]
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Battery
[/TD]
[TD]3200 mAh, 14.8v
[/TD]
[TD]2100 mAh, 14.8v
[/TD]
[TD]2100 mAh, 14.8v
[/TD]
[TD]Increase
[/TD]
[/TR]
[TR]
[TD="align: right"]ESC
[/TD]
[TD]SS-60 / GPMM1850
[/TD]
[/TD]
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]ESC Motor Adapter
[/TD]
[TD]Not Required
[/TD]
[TD]Not Required
[/TD]
[TD]Not Required
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Motor Mount
[/TD]
[TD]Medium / GPMP1255
[/TD]
[/TD]
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Current Draw
[/TD]
[TD]46.4 amps
[/TD]
[TD]36.6 amps
[/TD]
[TD]36.6 amps
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Approximate Speed
[/TD]
[TD]59 mph
[/TD]
[TD]59 mph
[/TD]
[TD]59 mph
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Approximate Thrust
[/TD]
[TD]59 oz.
[/TD]
[TD]74 oz.
[/TD]
[TD]74 oz.
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Weight of Power System
[/TD]
[TD]18.1 oz.
[/TD]
[TD]15.6 oz.
[/TD]
[TD]15.6 oz.
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Approximate Flight Time at Full Throttle
[/TD]
[TD]4 minutes
[/TD]
[TD]3 minutes
[/TD]
[TD]3 minutes
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]Watts per Pound
[/TD]
[TD]129.62
[/TD]
[TD]102.26
[/TD]
[TD]102.26
[/TD]
[/TR]
[/TABLE]
On a 5S pack we get this recommendation
[TABLE]
[TR]
[TH][/TH]
[/TH]
[TH][/TH]
[/TR]
[TR]
[/TD]
[TD]Sport
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]N/A
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]Not Required
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]13x8 in., Electric
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]2100 mAh, 18.5v
[/TD]
[TD]Increase
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]Not Required
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]33.1 amps
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]63 mph
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]86 oz.
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]17.8 oz.
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]4 minutes
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD]115.47
[/TD]
[/TR]
[/TABLE]
If you were going to consider these motors then you would want to look at the physical specs to see if they will fit.
Specs for the plane:
Description
Specifications:
Wing span: 55 in / 1400mm
Wing area: 651 sq in / 42 sq dm
Flying weight: 4.6 - 5.3lb / 2100-2400 g
Fuselage length: 52in/1350mm;
Brushless out-runner: 8oz and up, A4520, LI-POLY 4S-5S 3700-5000mAH
Propeller: APC 14X7E, Spinner 2 - 2.5''
Radio Required: 4 channels, 5 servos
aeajr is offline
