E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Rimfire 50 Help
Reply
Old 12-05-2014, 11:48 AM
voodoodb
My Feedback: (97)
voodoodb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Rimfire 50 Help
Just purchased the RImfire 50 for my nearly completed FW190. I got on youtube and found a couple of vids of guys flying big warbirds using the Rimfire 50. Setup with 160esc and 12s packs running 22x12 prop. My question is that when you load this into the ecalc calculator it says max power over limit. 7825 watts, and case temp to high 315. And Voltage close or over limit 38.16
Is this need to worry? The video shows no problems.
voodoodb is offline
Old 12-05-2014, 08:32 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Let's start with complete information. There is no Rimfire 50 motor that I can find.
http://www.electrifly.com/motors/gpmg4505.html
What motor do you have?
There is a Rimfire .55 but that is no where near the power you mention.
There is a Rimfire 1.20 that is 50 mm wide but that is not a Rimfire 50.
There is a Rimfire 50CC that might be what you are talking about.
Manual:
http://manuals.hobbico.com/gpm/gpmg4800-4805-manual.pdf
RimFire 50cc (80-75-230) (GPMG4800)
Motor Output Shaft Size: 10mm
Motor Diameter: 80mm [3.14”]
Motor Can Length: 75mm [3.0”]
Mounting Space Length: 87.3mm [3.44”]
Weight: 1250g [44.1oz]
Input Voltage: 33.3-55.5V (9-15S LiPo)
Max Continuous Current: 110A (at 12S)
Max Continuous Power: 5000W
Max Surge Current: 135A (at 12S)
Max Surge Power: 6500W
Prop Range: 22x8 to 26x10 glow/gas prop
Sport Aircraft Weight: 12.7kg [28lbs] [460oz]
3D Aircraft Weight: 8.17kg [18lbs] [288oz]
Which one do you have?
Assuming it is the Rimfire 50CC, the max specs are shown. Exceed them at your own risk.
aeajr is offline
Old 12-05-2014, 08:41 PM
voodoodb
My Feedback: (97)
voodoodb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
50cc
voodoodb is offline
Old 12-06-2014, 12:25 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Info added to my previous post.
aeajr is offline
Old 02-05-2015, 09:18 PM
Eddie P
Eddie P's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Voodoo, have you installed your Rimfire 50CC yet?
I might be using one in a Hangar 9 30CC Spitfire. It's a bit much of a motor for this plane but I need a lot of lead in the nose if I use something smaller, less capable and I don't really save weight that way. I've also seen the videos and spoken to the guys doing the 50CC on 12s. It's a monster setup. It makes all the right kind of thrust, noise, etc. However, the amps are a little high IMHO for longevity and flight times. I am hearing from guys who have the motor installed that they are getting 135 amps Wide Open initially and settling down to the 100 amp range WOT in flight. That's pretty high IMHO but completely doable if you have a lot of motor / ESC / Battery cooling.
In my case with a Spitfire, it's a closer cowled aircraft and cooling is an issue at these power levels. I believe I might be looking to use a 21" prop, or potentially a 22" x 8" just to try it out and see what I can get at slightly lower power levels. Based on the in flight speeds of 100-135 mph on the 22"x11" prop, I have a feeling the 22x8 will give, maybe, 85 mph in flight with unlimited vertical for something weighing less than 25 pounds. I don;t think an 81" Spitfire really needs to go 135mph for me, but it does sound amazing and is impressive to see. Just the same, propping down to something in between (like a 22x8) is probably what I'm looking to do.
Eddie P is offline
Old 02-06-2015, 08:07 AM
voodoodb
My Feedback: (97)
voodoodb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not yet. Just got my CC 160 esc in. I will run it on the test stand this weekend. I will be trying a 21X13 prop. After running through several calcs this was the best combo I could come up with. Also the CC ESC has data logging so I can see what it is actually doing.
voodoodb is offline
Old 03-19-2015, 05:57 PM
thrawn150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have this motor and edge 160 HV on my H9 P-47 30cc. I use the 22 x 8. Plenty of power and not taxing the system. I can not stress enough that you NEED TO UPDATE THE ESC FIRMWARE. This setup sucked when I first put it together last spring, then in July they updated the firmware and wow what a difference. I have a not so great video of this setup on Youtube, check P-47 30CC thrawn150 if interested.
thrawn150 is offline
