E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Battery recommendation
Reply
Old 05-05-2016, 12:47 AM
Prboz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question Battery recommendation
Hi Everybody,
Building a Future shock for a friend and have the following to put in it but need a recommendation on a battery.
Emax GT3520/04
[TABLE="class: MsoTableGrid"]
[TR]
[TD]
Model
[/TD]
[TD="width: 86"]
Cell Count
[/TD]
[TD="width: 86"]
RPM / V
[/TD]
[TD="width: 86"]
Prop
[/TD]
[TD="width: 86"]
RPM
[/TD]
[TD="width: 86"]
Max Current <60S
[/TD]
[TD="width: 86"]
Thrust
[/TD]
[/TR]
[TR]
[TD="width: 86"]
GT3520/04
[/TD]
[TD="width: 86"]
3S
[/TD]
[TD="width: 86"]
1150
[/TD]
[TD="width: 86"]
11X5.5
[/TD]
[TD="width: 86"]
10300
[/TD]
[TD="width: 86"]
47A
[/TD]
[TD="width: 86"]
2300g 5.07lb
[/TD]
[/TR]
[TR]
[TD="width: 86"]
4S
[/TD]
[TD="width: 86"]
1150
[/TD]
[TD="width: 86"]
10X5
[/TD]
[TD="width: 86"]
14000
[/TD]
[TD="width: 86"]
54A
[/TD]
[TD="width: 86"]
2800g 6.17lb
[/TD]
[/TR]
[/TABLE]
80amp ESC
Keep looking at 4S 5000mah 50C battery but have a feeling this is overkill.
Help much appreicated
Future shock would way closer to 2 Kilos.
Peter
Prboz is offline
Old 05-19-2016, 06:14 PM
chuckk2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is this the model?
Designed by Bill Evans, Future shock is the latest in the Simitar Series of tailless aircraft. It has a balsa-and-ply fuselage and a foam wing, and the plans show two versions- electric powered and glow-powered. Patterns for the foam wing's root and tip
Additional Information: are also included, and foam wings are available from Soaring Research. WS: 56.5 in.; L: 32 in.; power: .25 motor or .40 glow engine.
If so 3 or 4 S lipos at about 3000mah should be enough. (Assuming that the motor you selected is really appropriate!)
chuckk2 is offline
