charging lipos with an astro flight 109
I have a Astro flight model 109 Lithium charger and I am wondering if I can power it with
a Pyramid Model PS-12KX regulated power supply
specs as follows
Output 13.8 VDC
10 amp constant
12 amp surge
the astro flights instructions say to use a 12 volt regulated supply or auto battery
and I am concerned that the 13.8 volts the power supply puts out will be too much input voltage
am I safe using it ?
Greg
specs as follows
Output 13.8 VDC
10 amp constant
12 amp surge
Greg
My Feedback: (21)
RE: charging lipos with an astro flight 109
Buy the Corsel power supply from www.lightflightrc.com for $22.00, its worth much much more then that ($150 new if you were to buy it from factory) and it much much higher quality then the Pyramid supplys. You just need a cord and your good to go
