Battery repair Help
UT
Battery repair Help
I have a battery pack that the positive tab came off of the battery. It was not a solder connection. Was more like a little tiny spot weld. Anyway, I need to know if anyone knows how to repair this connection without killing the cell. Is there anything I need to do to prepare the cell top before soldering. I have an excellent soldering iron and good soldering abilities. It is a AA size NiMH pack. I am guessing I would use high heat and get in and out fast. Any suggestions are greatly appreciated.
Shaun
Shaun
RE: Battery repair Help
you will need to scuff the surfaces to be soldered, and after that just solder it. I go for the high heat (40w) setting and get in and out fast, but going low and slow works too
My Feedback: (21)
Make sure it's an IRON, not a soldering gun. It needs to have a big chisel tip to transfer lots of heat quickly.
Soldering cells is easy with the right prep. I kiss the top of the cells with a Dremel sanding drum, then tin them.
UT
I kiss the top of the cells .....
I did what you said...I kissed the top of my cells. Then I scuffed 'em, fluxed 'em, tinned 'em, and soldered 'em. Got in and out quickly. Now for the next question. I put the pack on the charger for its first charge. I am letting it trickle charge for the first couple of times. With the pack trickle charging I can put the pack to my ear and hear it buzzing. Is this a normal thing? I am kind of new to electrics! Hope the kissing thing worked!
Shaun
