Charging Kokam 340 mAh Lithium Poly cells
ON, CANADA
I am wondering if I can charge the Charging Kokam 340 mAh Lithium Poly cells higher than 0.7C? I have a triton charger.
I understand from some specs that they are rated as Super High Discharge. What about Super High Charge???
RE: Charging Kokam 340 mAh Lithium Poly cells
NO, no lipolys can be charged higher than 1c. You should be charging that on at 0.3 on your triton. Higher than that can make them go BOOM!!!.
