Best Price on big thunder power packs!
AR
I'm trying to find the new 10-12C cells in a 5s4p 8000mAh pack. When I go to the Thunder Power site all that they show is the older 5and 6 C cells. Could someone suggest a good retailer for these cells?
Darrell B.
Darrell B.
My Feedback: (16)
IL
RE: Best Price on big thunder power packs!
Is this what you're looking for?
TP8000-5S4P 8000mAh, 5S4P (18.5V) 13 gauge wire
Rating: 8-10C Max Avg Discharge (65A/85A burst)
Output: 18.5V Nominal, 8000mAh
Applications: Sub C replacement for 3D aircraft and helicopters.
Dimensions/wt: 13.5"x 1.75"x 1.15"/30oz.
and/or
TP8000-5S4PV 8000mAh, 5S4PV (18.5V) 13 gauge wire
Dimensions/wt: 9"x 3"x 1.15"/30oz.
If so, then try Esprit Models. I've had very good service from them and check their "Good Deals" Page for a way to save some $$$ (you have to say "Esprit Model is the best" in your order and it can save you up to $25. Sort of a "Phrase that Pays."
[link]http://www.espritmodel.com/[/link]
Berwyn Bill
and/or
Berwyn Bill
AR
Are these the most current version of the thunder power batteries? I thought that I had seen some that were rated at 12C with burst to 15C. I can't seem to find them now, but several conversions that I have read about have used them.
Darrell B.
Darrell B.
My Feedback: (16)
IL
The only other TP8000 5S4P that I can find is on that's rated 10C/12C and it's being sold through an UK site:
[link]http://www.skylinemodels.co.uk/acatalog/Lithium_Polymer_Batteries.html[/link]
I haven't ever seen an TP8000 pack in the 12C/15C range. Not saying it ain't out there, just I can find it. Good luck!
BB
PS - I did see a site that lists a TP8000 5S4P as being "Rating: 8-10C Continuous Discharge / 15C Burst" but that sounds a bit off. See for yourself:
[link]http://www.tppacks.com/products.asp?cat=10[/link]
Best to email the guys at Thunder. They'd know best what the real ratings are.
BB
AR
Thanks for the input guys. I just realized that it was tanic packs that are rated at 12C. The prices on the THunder Power packs are really good at esprit. Good information.
Dose anyone have any experience with the Tanics. Are they as good, better, worse than the Thunder Power packs?
Darrell B.
Darrell B.
