Charging leads for the Accu Cycle Elite
VA
Hey guys I am about to buy my Accu Cycle Elite Charger. I am having a hard time with finding what I will need in lines of charging leads.
http://www2.towerhobbies.com/cgi-bin...&I=LXEYD4&P=ML
The batteries I will be charging with it have deans connectors..I cant seem to find any premade leads so I am assuming I will have to make them myself...
If I have to make them myself do I need these....
http://www2.towerhobbies.com/cgi-bin...?&I=LXL362&P=M
AND These....
well 4 males(2 leads) http://www2.towerhobbies.com/cgi-bin...?&I=LXHGL9&P=M
I also will need.. http://www2.towerhobbies.com/cgi-bin...?&I=LXKX26&P=M
Is this correct or does someone have a place online that sells these as pre-made leads?
Thanks for the help
AND These....
Thanks for the help
RE: Charging leads for the Accu Cycle Elite
If you don't want to make a cable maxxprod.com has exactly what you are looking for ,
2792 Dean's Ultra Plug w/Banana Plugs $5.00
Try this llink http://www.maxxprod.com/mpi/mpi-5.html
click on the link above and scroll down until you see part 2792 on right side.
Before you spend $6.99 for 2 feet of wire see below!!!
If you want to make cables check the links below
For silicon wire
http://www.unipros.com/cbpsite/produ...sion_id=188183
http://radicalrc.secure-mall.com/sho...54&cart=235236
Try these links for Deans connectors
The shipping from Radical RC is only $2
For silicon wire
