just got the Hobbico mk2 charger//..
man,,this thing is tiny...it looks much much bigger then the pictures online..I really like how small it is...hopefully it works great too..
RE: just got the Hobbico mk2 charger//..
this charger seems to good to be true for only $50..charges 2 batteries at the same time..along with lipo/nimh/nicd..is very small and light in weight...and even beeps outloud when the packs are fast charged and the trickle charge is engaged...also has a safety feature where if there is an error when you 1st plug your battery pack in...it beeps and the lights on the unit blink...
AR
The charger is just fine. That is the one I use to charge my Li-Po's and have had NO problems. I, also, charge my NiMH's with no problem. I have been using it for about four months now.
Since I just recently got the newest version of the AstroFlight Super 101 to check how many amps my motors are drawing, I just attach it to the MKII and it tells me the charge voltage, charge current and the total mAh I am putting into the batterys!
