charging a 8.4v 3300 Nimh battery @ 1.5amps
My Feedback: (15)
IL
Hi Guys,
I want to charge my 8.4v 3300 nimh battery, but my nimh charger will only charge at a max rate of 1.5 amps. Is there a problem with this other then it will obviously take longer to charge?
thanks,
Frank
thanks,
Frank
RE: charging a 8.4v 3300 Nimh battery @ 1.5amps
You'll be fine....don't worry, but that is as long as your charger can detect peak charge. Make sure you don't charge your batteries in the house....do it in the garage on the concrete floor or onsite.
Cheers.
Cheers.
