Programing E-Flite new 20 amp ESC
NV
RE: Programing E-Flite new 20 amp ESC
The cut off voltage is set automatically when you plug in your battery pack...
Any pack 11v+ (ie - 3S LiPos, 10 cell NiMh, etc) will be set for a 9v cut off. Any packs below 11v (ie - 2S LiPos, etc) will be set for a 6v cut off.
With the current models, you can not set the cut off voltage yourself - only the brake on/off.
My Feedback: (7)
ok here some stuff that might help you i have a 20a brushless esp ill copy dow what it says for programing method for the brale
1. disconect the esc foromthe bat, and leave disconnected for at least 30 sec to alow the esc to reset. turn your tx on
2.move the throttle control on you tx to full throttle
My Feedback: (7)
oops hit enter on acident
3. plug in the battery to esc
4. wait 5 sec's you should hear a second beap agter the intial power-on beap
5move the throttle controlon you tx to the center position
6.wait another 5 sec'c you will hear another beap
7. move the throttle control back tofull throttle and wait for anther beep
8. move the the throttleback tothe center position and you will hear 3 beps
9.to turn the brake on move the throtle back to full
10. to turn the break off moce the throttle downto the off position.
11. dosconnect the battery.the break is now programed
i hope that this can help cause mine only has preset cutoff point
