30A charging current to 800mah LiPo 3cell
AZ, TURKEY
I'm using Triton charger. When I tried to charge the LiPo 11.1V 3cell it read 30-35A charging current. Usually this charging current is much below this value. So I unplugged it. Do you think this is sometimes normal, or what? I do not know about the brand of the battery. I did not continue to charge it, didn't know what should happen. Any ideas?
Banned
My Feedback: (9)
RE: 30A charging current to 800mah LiPo 3cell
ORIGINAL: Behzat
PA
1) You are supposed to program in the max charge current for your LiPo pack before charging... an 800mAh pack would require a max setting of 0.8A (800mA).
2) The Triton will allow a max of 2.5A for LiPo cells
AZ, TURKEY
Sorry to dissapoint you but it was 30A. We saw 30A and looked at each other and stopped the charger directly, since we knew something was wrong. Since you insist on, I will connect again and observe more clearly from a little distance and tell you. There also was no smoke.
AZ, TURKEY
Yes I was mistaken, what it wrote was 30V. Our second LiPo also saw 30V on the Triton. Do you think this is normal???
