Thunder Power Charger
The one I am looking at specifically is this one: http://www.ehobbies.com/thp425.html
It needs a 12V power supply, rather than trying and experimenting will any 12V power supply work?
Also I have been looking at some of the E-flite chargers, like this one: http://www.rcmodels.com/eflc3005.html. What else would I need with that?
RE: Thunder Power Charger
Ok, a bit paranoid here so I'd figure I would ask.
I have a 12V 1.5A charger with the right connection for the charger. I have 2 LiPos, one's a 7.4V 1500mAh Kokam and the other is a 7.4V 1900mAh Thunder Power. Both are 2 Cells. The charger should work fine, right? As long as I set the charger correctly.
