60amp ESC $50!!!
CA
60amp ESC $50!!!
Hi, i was wondering if this was a good ESC to go with an AXI 4130/16 on a 6Cell Li-poly battery. I found these 60 amp ESC's on ebay and they were about $130 less than jeti 77 ESC.
I believe the AXI i am purchasing can max out at 50 amps so I should be ok right? The only problem that I found is that the speed controllers on ebay are only for 5cell lipoly. Would it work with 6cell? I would also like to take advantage of the LVC but since those are just made for 5 I think the ESC would not recognize it.
And also, when the ESC says te Low voltage Cutoff is programmable, does that mean I can specifically put my own voltage or just by cell count?
Here are the ESC's: 1. http://cgi.ebay.com/RC-Smart-60A-Bru...QQcmdZViewItem
2. http://cgi.ebay.com/RC-60A-ESC-Brush...QQcmdZViewItem
3. http://cgi.ebay.com/60A-ESC-Electron...QQcmdZViewItem
Thanks Sam
Thanks Sam
My Feedback: (24)
GA
RE: 60amp ESC $50!!!
Link 2 and three say good for only 5S and I think they are all the same controler. All of the China made ESC that I have seen are only good for 5S pack's. The CC ESC are good for 6S and I think less than $100.00
Milton
Milton
