Lipo size ...
Lipo size ...
Ok , So I'm looking to put together a GWS Slow Stick with a EPS400C power system.
REQUIRES: Speed Control: Or auto-cut-off
Battery: 2/3 AA cells 270-400mAh or AA cells 600mAh 7.2V
Charger: Timed or peak for 2/3 AA cells
Radio: 2-4 Channel
Servos: 2 Naro,Micro,or Mini servos
(1-elevator, 1-rudder)
Using a
Great Planes ElectriFly C-12 Micro Brushed ESC w/BEC that is lipo ready.
What type of lipo should I use, or what is safe to use ?? 11.1 or 7.4 ?? how many mAh ??
Can you tell I'm very new to Electric ??[&:]
Radio: 2-4 Channel
Using a
RE: Lipo size ...
Depends on what gearing and propeller you have. Take a look at this:
http://www.gws.com.tw/english/produc...em/eps400c.htm
The same tables should be on the CD that came with the kit.
About 1200mAh LiPo should be enough if it is around 10C (12 amps) capable pack.
