Triton charger
Triton charger
Ok , just got my charger and am going to give it a go. I just want to make sure I don't blow a Lipo !!
600mAh Standard charge rate at 0.3C = 0.2A Quik charge rate at 0.7C = 0.4A Max voltage per cell 4.2 volts.
So , I have a 600mAh 7.4 volt 2s Lipo , I don't have the heat probe , is it safe to quick charge and what should the voltage be ?? I'm not flying anything Hi-po or flying comp , I'm just flying for fun.
My other battery for my foamy is a Great planes Lipo , 640 mAh 11.1 volt 3s
Andy
Andy
My Feedback: (21)
RE: Triton charger
I believe the Triton uses nominal voltages for LiPoly battery settings. So, if you have a 2-cell, or 7.4V LiPoly, you would choose 7.4V from the menu. For charge rate, choose the rate recommended by the battery manufacturer (i.e. .4A). All other settings can be left default.
