will eflite power supply work on Kokam 403 charger?
PA
i have an eflite power supply that came with my Blade CX heli. I've been wondering if I can use it to power my Kokam Lipo403 charger, and charge 3 cell lipos with it. right now i'm using my 12v gell cell. the power supply reads, output 12v 1.5 amp.
RE: will eflite power supply work on Kokam 403 charger?
1.5A (1500mAh) is barely enough to run the charger itself, never mind to actually charge a battery.
You need a power supply with at least the current capacity of the largest battery you'll be charging, plus additional capacity for the charger itself. A 12-volt 10A power supply is a good choice as a starter supply for charging small packs.
In my experience, you'll never regret buying a larger power supply than you presently need.
- Jeff
- Jeff
There are dozens of suitable power supplies available. Probably the most readily available are those from Radio Shack, [link=http://www.radioshack.com/product/index.jsp?productId=2103960]such as this one[/link]. Radio Shack products aren't necessarily the best value, but they will usually do the job.
Hopefully, others will suggest specific models from other companies.
Note that "12-volt" power supplies usually have an actual output of 13.8V, which matches the voltage of a typical car battery.
- Jeff
- Jeff
