hobbyzone brushless lipo conversion
Hi I want to switch to brushless lipo setup.
Can someone share there succesful conversion?
What did you use for the following?
Motor
speed control
battery
prop
motormount adjustments?
Please help with any pertinent info.
Motor
speed control
battery
prop
My Feedback: (21)
RE: hobbyzone brushless lipo conversion
Is that the RTF model? If so, you'll need a complete radio and servo overhaul because the integrated electronics in the plane now are not compatible with standard brushless controllers.
Yes its the RTF one with propietory crap. I also bought a stripped fuselage wing and tail set of this plane. The stripped one is the one i plan on putting the brushless in. I also would like to re-use as much of the stuff in my next electric plane which will be a goldberg eagle 400 ep.
