thunder power and polyquest balancers...
NY
Do thunder power and polyquest battery packs have the same balance connector? If so, what is the best balancer to use with these packs?
My Feedback: (314)
RE: thunder power and polyquest balancers...
I've been using the FMA Cellpro 4 Charger/Balancer. You can buy an adapter that on one side charges ThunderPower and next to it are ports for Polyquest. It works beautifully. They have other adapters available as well. Check www.fmadirect.com.
