Photo 3v lithum batteries put together
BC, CANADA
Is it ok to put together 4 of the 3v lithium cells,1300mah, to use with my brushless motor and phonix 25 esc? is 12v battery ok for the motor and esc? was done b4
FL
RE: Photo 3v lithum batteries put together
UMMMM, voltage may be ok but not real sure on how it will hold up to the amp draw. Need more info, as in what is the draw from the motor, and what is the C rating on the cells.
TN
Forget it - it is highly unlikely that those 3v Lithiums can provide any decent amp draw - they are probably limited to a few amps at most (maybe even <1A). Consumer cells for electronic gadgets are VERY different from RC specific cells.
