lipo packs & prop selection
Hi Everyone
I have a question on which lipo battery should I use on an airplane I have.
The plane is a Lil Rascal with 30" wingspan, 10 oz. flying weight, 28-26-1000 rimfire outrunner brushless motor, 12 amp silver series ESC. The stock motor on this plane is a 180 size brushed & geared motor and comes with a 6" propeller that makes the plane look scale.
Since the new motor has a lot of more power than stock motor I'm concerned with torque. The new motor turns 1000 revolutions per volt so I'm inclined on using a 7.4 volts pack and I'm willing to increase prop size to a maximum of 7"X6" to deal with power & torque.
What pros/cons 7.4v & 11.1v have (aside from weight & size) and which lipo pack (2c or 3c) do you suggest for this setup?
Which size & type (slow flyer, APC or GWS orange type) do you suggest for this setup?
Any help will be appreciated,
My Feedback: (13)
CA
RE: lipo packs & prop selection
prflyer
Go back to the motor manufacturer's specs and start there with the recommended prop size. Even check that with a watt meeter to be sure you are drawing less than the controllers maximum. If you don't have a watt meeter, quit flying until you do. It's about as necessary as a prop. Battery, a 3c is going to give you more performance and duration compaired to a 2cell. Lil Rascal is a sweet flying sport bird with limited airobatic ability, high lift wing. You should be able to carry a 1320 or so battery. Any battery you buy today should be capable of 20C if its not old shop stock. I have been buying my batteries from United Hobbies for the past several months based on a flying buddy's experience of more than a year with the Zippy 20-30C and higher quality Polly Quest. My experience for 3-4 months has been also good. Get the same flying time (3D) as with my Thunderpower and max amp cells for about 1/2 the price. No bad experiences to report. Have ordered on a Friday and received order on Monday. Don't know how that one was done, but true, usually a week. Better than some USA shops. ENJOY
TN
ORIGINAL: prflyer
Hi Everyone
Hi Everyone
You need to balance battery voltage versus prop size (and keep the motor within its max amps/watts limits). Now that is a 1000Kv motor which is rated for 12A/135W continuous and 15A max. "surge". With such a low Kv you will HAVE to use 3s, otherwise you will need a ridiculously large prop to make the most of the motor. For 3s I would suggest a 10x6 GWS HD: my testing produced this: 10.9v, 10.35A, 112W, 6870rpm, 39.0mph, 673g, 23.70oz, 6.01g/W. A 10x4.7 AC SF drew just over 12A and the motor got VERY HOT, VERY FAST. I think their 15A max is pie in the sky!
On 3s you could be very tentative and use an 8x4 GWS HD, if a 10x6 GWS HD is too big for the plane, though an 8x4 would only draw 5.25A/57W and get you 14.68oz @ 33mph. I'd guess that a 7x6 on 3s would draw about the same.
If you were to use 2s and the 7x6 you mentioned, I doubt you'd draw more than 3A. To get anywhere near 12A draw on 2s you might need a 14" prop, and I can assure you that motor doesn't have enough torque to swing something that size [nor would you have any ground clearance]!
