Charger Adapter Cable
I recently bought two Tenergy 3-cell Lipo's, 2200 mah. I also bought a ParkZone charger PKZ1040. Naturally, and too my dismay, the charge connectors are not compatible! The batteries have a Thunder Power type connector and the charger has the standard E-flight connector.
Does anyone know of a source for an adapter that would interconnect these two different charge connectors? I'll much appreciate any advice.
Frank
Frank
FL
RE: Charger Adapter Cable
Frank, check with places like www.cheapbatterypacks.com They carry all kinds of adapter connectors. You may be able to just buy the correct style outer connector and swap your packs leads into it. Then you wouldn't need the harness.
