can I run two chargers off an 18amp power supply?
I have an 18amp power supply and I wanted to know if I can speed up hte charging process with two chargers?
RE: can I run two chargers off an 18amp power supply?
It depends on how much power do you need on every charger.
Charging a 3s2200maH LIPO at 1C, requires around 3Amp on a 12V power supply, 6s5000MaH requires about 6.5Amp.
A 12V 18Amps power supply should be good enough for your application.
My Feedback: (15)
I had the same question , I am a newbee to e-flight and useing a home conversion indi power station 10 , and then I want to run two charges a astro lithum delux and a Trtion , my , have two batterys both thunder power 11.1 volt 2100mah , is that ok to run two charges off that power supply ?
My Feedback: (325)
same math applies. Figure the total power in watts.
If you'll charge the batts at 2 amps then 12.5 voltsx2 amps x 2 = 50 watts. The ps needs to be at least 50 watts.
