Go Back  RCU Forums > Electric Aircraft Universe > E-Flight Power Sources
Reload this Page >
12V charger for 9.6V battery?
E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Old 03-14-2009, 08:59 PM
R/CFlorin
Default 12V charger for 9.6V battery?
I don't want to risk getting the battery burned out, so I hope some of you guys here can help me out
I have a 9.6V N-500A Nicad battery (I think that means 500 mah), and my only charger is rated at 12V 1.1A output. Is that too much for the battery to take?
Old 03-15-2009, 10:40 AM
soarhead-RCU
Default RE: 12V charger for 9.6V battery?
Is this a TX pack????? If it is I would say that 1.1A will cut into its lifespan a lot. Most TX and RX packs do not like fast charging. If the batteries are made for a power pack then they will be OK ussually at the 2C charge rate. The internal resistance is lower on a high discharge pack so heat is not built up at higher charge rates.
If it is a TX pack I would say you should get a regular 50-55ma output wall charger. The 12V part is OK because a fully charged 8 cell pack will peak at around 12V.
If it is a power pack, they should be charged in about 1/2 hour, they will heat up andthat means they are charged. If it is not a peak charger and cuts off automatically stay with them and as soon as they get warm unplug them...or they will be Toast!!!!!
Bob
Old 03-15-2009, 07:35 PM
Dr Kiwi
You really need a "proper" charger - a wall charger at 50mA would do, but you should get an AC to DC power supply (maybe 13.8v, 10A) and a dedicated DC charger suited to NiCd and NiMh. Then you can charge Nixx flight packs as well as your Tx pack. If you intend to get into Lipo's get a Universal Charger which can cope with all battery chemistrys.
