lipo size for setup
lipo size for setup
hi ,ive got an overlander breeze 40 size trainer 59" wingspan flying weight 4.4lbs ,i'm dropping in a E-Power 2826 950KV 45A Brushless Outrunner 189grams,hobbywing pentium 60 amp cont /burst 80amp esc ,12x8 master airscrew prop,can you tell me what "c"rate i need for 3's or 4's lipo , i'm thinking between 3000 to 4000mah's ,i should have done a maths and physics degree , ha ha, i don't understand amps / current / volts all i want to know is what battery to put with it , ie( 4's 3600mah 25c )prop can be changed if need be please help this plane needs to grab some air before it turns into a dust catcher
