Has someone tried Rimfire 300 28-22-1380 on 2S and 8x3.8 apc
TN
RE: Has someone tried Rimfire 300 28-22-1380 on 2S and 8x3.8 apc
This is what Motocalc computes for that:
Motor: Great Planes Rimfire 28-22-1380 (#4505); 1380rpm/V; 0.4A no-load; 0.3067 Ohms.
Battery: Thunder Power TP1350 (G4 ProPower 30C) (30C); 2 cells; 1350mAh @ 3.7V; 0.016 Ohms/cell.
Speed Control: Castle Creations Phoenix 25; 0.0065 Ohms; High rate.
Drive System: Direct; 8x3.8 (Pconst=1.69; Tconst=1) direct drive.
Airframe: Anything you want.
Motor Amps = 6.3
Motor Volts = 7.2
Input (W) = 45.2
Prop RPM = 6502
Thrust (oz) = 10.1
PSpd (mph) = 23.4
Motor Amps = 6.3
Motor Volts = 7.2
Input (W) = 45.2
Prop RPM = 6502
Thrust (oz) = 10.1
PSpd (mph) = 23.4
