E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
E-flite 25 on Pitts model 12
Reply
Old 07-19-2010, 01:48 AM
DenizY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default E-flite 25 on Pitts model 12
Does anyone have a Pitts Model 12 with the Power 25 BL motor installed? I mounted it per the eflite instructions and it sticks too far out of the cowling. I have 3/4" of an inch between the cowling and the back of the prop. The instructions tell you to use 20mm spacers between the mount and the firewall. Any help would be great.....
DenizY is offline
Old 07-22-2010, 05:47 PM
stimul8tor
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: E-flite 25 on Pitts model 12
I'm not a real experienced builder, but I had a similar problem. I put eflight .10 on parkflyer cessna skylane 180. The motor stuck out too far to get cowl on. the mount to motor to firewall is wood. I cut the sides off and shortened them keeping the angle the same. I used 3/16 beech a braced the inside with balsa blocks. I used 5 min epoxy on the whole thing and it's strong and tight most important the cowl fits.
stimul8tor is offline
Old 08-08-2010, 09:04 PM
DenizY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question for all the electric gods.....I have a Eflite power 25 on my pitts currently running a extreme flight 60A esc , a 4350 3s battery and a 12x8 prop. Can I run a 2200 4s battery with a 12x6 prop? Pros and cons?????
Deniz
DenizY is offline
Old 08-08-2010, 09:06 PM
DenizY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Deniz
DenizY is offline
Old 09-07-2010, 12:51 AM
Aircraftfreak15
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you can always put smaller spacers in or no spacer.
Aircraftfreak15 is offline
