Lithium Polymer Charger?
You can use same charger for lithium polymer cell as well.
kokam lipo 402 charger is the right and adquate charger ever built for e-flight. contact www.fma direct.com.
you can select 1s/2s/3s/4series connection and also pararell connectioned current slection up to 1.6A is possible.
kokam almost developed high power lithium polymer charger and protection module(safety guard) even for the bigger than 400 motors.
for high power and high current drain
new 1500(mah)HD and 2000(mah)HD are recommendable
in case of 1500HD,10series,5pararell connection,you will get 37volt average,7.5Ah continuius draw of 45A,short draw 75A
In case of 2000HD cell same connections,37volt,10Ah,CONTI-70A,short 100A.
The kokam 10 series connection/max 8 amp current supply charger will come soon in addition to lipo-402 charger.
