Go Back  RCU Forums > Electric Aircraft Universe > E-Flight Power Sources
Reload this Page >
Buying extra Lipo battery and I'm a little confused..... ??
E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Reply
Old 08-18-2010, 12:37 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Buying extra Lipo battery and I'm a little confused..... ??
My plane uses a 3 cell Lipo, 1800mah - 15c
I'm wanting to buy an extra battery that is a little more powerful for longer flight.
I found one cheap that is 11.1v 2200mah and 20c..... I'm just not sure which number I need to increase and why?
CGCINC is offline
Old 08-18-2010, 12:39 PM
exeter_acres
exeter_acres's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Buying extra Lipo battery and I'm a little confused..... ??
loosely...
the mAh number is the "fuel in the tank"
bigger number, more run time... but you can't go crazy because a bigger battery can be heavier so it takes for power to fly it.... a trade off
exeter_acres is offline
Old 08-18-2010, 12:53 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: exeter_acres
loosely...
Ok.. thanks! Thats a good, easy description I can understand.
What does the C stand for... Current? Capacity?
AND, what is the higher numbers for? I'm guessing a bigger draw in power?
CGCINC is offline
Old 08-18-2010, 02:20 PM
exeter_acres
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
C means a few different things...
in this example it means the discharge rating of the battery....
so an 1800mAh battery rated to 15C is capable of discharging at up to 27 Amps....
here is a site with lots of info...
http://www.hooked-on-rc-airplanes.co...ery-packs.html
I have not read everything and cannot vouch for all of its accuracy, but what I saw looked pretty good.
Old 08-18-2010, 02:23 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That link helps.. Thanks!
CGCINC is offline
Old 08-26-2010, 01:38 PM
plane-addict
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You said you want longer flight, but that is only possible with a trade-off: Heavier batteries.
I am using the new Nano-tech batteries. They are about the same weight as the 'normal' lipo batteries, but can handle higher discharge, which means most of the time that you will keep the same power longer because they can provide the power easier.
Most importantly, the charge rate of these batteries is about 5C, so you can charge 5 times faster than with a conventional lipo battery. So, shorter pauses between flight, means more time to fly.
Have a look here if there is something that suits you: http://hobbyking.com/hobbyking/store...8&ParentCat=85
plane-addict is offline
