E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
blade 400 servo hookup
Reply
Old 01-15-2011, 03:44 PM
coralcape
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default blade 400 servo hookup
Got a swap met blade 400, need to know servo hookup using a e-flite micro 6 ch rcvr. Hooked it up using futaba pattern and pitch and roll seem reversed. Thanks , red
coralcape is offline
Old 01-15-2011, 05:58 PM
JPEE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: blade 400 servo hookup
ORIGINAL: coralcape
Hello Coral,
I am not quite sure what you asking, but I will try to help.
Aux 1........... is the pitch servo, I make the right side of the heli the pitch side.
Gear ............is the one yellow wire from the gyro
Rudder......... is the other wire from the gyro
Alieron........ .is id theAlieron servo which in the left side, or drivers side like a car.
Throttle....... is the wire from the ESC
Battery........ is only used to for binding the helicopter to your radio
Be sure to note the positive and negative polarity of the recevier! On the side of the receiver there is a small + - to show you which is which. Black and brown wires are negative. On that one gyro wire lead that only has two wires, the black wire goes down too
I hope that helps JPEE
JPEE is offline
Old 01-15-2011, 07:13 PM
coralcape
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks JPEE for the quick response. I realize now I should have put more info. First I have very little knowledge of helos, I am comfortable in fixed wing. I am using a 72mz 9C futuba with a e-flite 6 ch micro receiver. I have the B400 manual, but it only refers to the spectrum setup. I guess what I need is the specific servo to channel hookup. I will try the info you sent and see how it goes. Thanks for the help. red
Old 01-15-2011, 10:13 PM
Solman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gear ............is the red stab that has two wires from the gyro
I believe you have it backwards. The single yellow wire is your gain wire and is suppose to go to the gear channel. That is if you are using the stock E flite gyro.
Solman is offline
Old 01-16-2011, 01:35 PM
coralcape
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tried the hookup per instructions, no joy. The only control that works OK is the elevator. I think I need to get some info on programming the transmitter first and then do the receiver. I'll check at the field and see if I can find someone familiar with Futaba. Thanks again, red
Old 01-16-2011, 02:04 PM
JPEE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: coralcape
Coral,
FIRST my good friend Solman caught my error. It is the single yellow wire from the gyro that goes to the gear prong on the receiver. I have corrected that error above as well. I have 7 helicopers and several different gyro's hence my rememberence error, I had another gryo pictured in my mind.
You cannot mix a Fatuba 72 mh FM radio with a any Spectrum receiver product. For more clarification you can contact Horizon Hobby FREE at:
Contact our Customer Support staff by phone at:
(800) 338-4639
Hours of Operation:
Monday – Saturday: 8:00 A.M. – 7:00 P.M. CST
Sunday: 12:00 P.M. – 7:00 P.M. CST
JPEE is offline
Old 01-17-2011, 05:04 AM
coralcape
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks again for the followup. The receiver I'm using is compatible with the Futaba 72mz. As I stated I can get some control, but with the motor disconnected and checking the head movement, it is not as it should be. I will ask at the field today for some help. Thanks. red
Old 01-17-2011, 05:08 PM
coralcape
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, rain today,no one at field. Took another shot at the transmitter and finally figured it out. Needed to activate the SR3 option and after a few servo arm adjustments helo is working OK. Thanks again for the info. red
Old 04-24-2016, 02:13 PM
Snowmonkey69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could you help me with a tactic receiver because mine only shows channel 1 through 6 and a batt port.
Snowmonkey69 is offline
Contact Us Archive Advertising Cookie Policy
