replace swash plate on my Blade 120 SR
In trying on my own to adjust the right side lean (which is common)on my 120 SR, (changed the distance on the swash plate links) now it will not hover unless you have almost constant stick input, mostly it wants to drift right.....I have pulled them off and put back to the 37mm stock settings but still wants to drift right andfwdin a hover. I have tried trimming it out. My swash plate maybe damaged as it looks like from pulling off the links so much in an attempt to adjust I bentthe part that attaches to the link...I can still fly it just needs more stick. So maybe I go to the LHS and get a new Swash plate.???
