vert tail support
vert tail support
does anyone have a good fix for a vert tail support? mine broke off my blade cp and theirs not enough left to get out unless I drill it, any help would be appreciated.....
NY
RE: vert tail support
Other than drill it, it seems that your only other option would be to get a new tail motor houseing... I'd just try to drill it though...
OH
You can drill it but you have to use a teeny tiny little drill bit. I just ground mine up and removed the dust with a shop vac.
Crash B.
Go Buckeyes!
Crash B.
Go Buckeyes!
A small drill bit in a Dremel worked well for me. The bit went for the carbon fiber rather than the plastic and turned it to powder. It was quite easy.
Chris
Chris
