Blade CP belt drive
MA
Blade CP belt drive
Hi,
We are releasing the blade CP belt drive together with fully cnc head and cnc tail, if you have any suggestions please feel free to post.
Steve
Steve
FL
RE: Blade CP belt drive
Will you still be offering just the frame kit (so I can use my BCP unit)? Price is a consideration for me as to whether or not I get this or just move to a larger, 400 size heli...
MA
Yes you can get the frame and belt drive separately.
- Belt drive and CNC frame:
Include CNC frame with belt drive system
* CNC Frame with G10 black fiber material
* All CNC parts with aluminum 7075
* Belt
* Tail Boom
Price: 55usd
Requirements:
Requires
* 1 x main shaft
* 1 x auto rotation main gear
* 1 x landing gear
Pricing 19.99usd for all 3 items above
For tail system requires
* 1 x complete tail system with all plastic parts (15usd separate)
OR 1 x complete tail system with all cnc parts (75usd separate)
This whole system can work with stock complete head or can use HDX300-HS
Steve
* Belt
* Tail Boom
Price: 55usd
Requirements:
Requires
* 1 x main shaft
* 1 x landing gear
Steve
NY
That's really cool. The only problem I have is that it seems like I'd be pretty much replacing everything in the CP, I may almost be better off just getting a new helicopter. On that point, you've got a real solid setup there, put it together with all your custom parts and sell it as a kit maybe! When do you plan on releasing it? I'll be sure to keep an eye on it.
FL
I'd like to see the video of it flying... in a format other than Real-Player. There's got to be one floating around on the net somewhere. Steve, in your opinion, Does this thing fly MUCH better than the BCP? I've been following all the feedback on the forums.... I want a micro that flys like a mini (read: more solid flight characteristics). I'd like to really be able to fly it in my backyard; not have to drive to a park to really wring it out.
CA
NY
I think it's going to cost more than 90 bucks to upgrade the cp with that anyways. I can't imagine getting that upgrade without a brushless setup, and if you go that far you may as well get your own receiver in there, then you need a new gyro, and new servos would probably help too. After your done with that, you're a little over 90 bucks I'd say, not to mention the only stock part left on it would be the head assembly, which they sell a CNC version of. That's all I'm saying. Ohh, I think I can convert that video for you, or you could just download virtualdub and do it yourself. From what I saw in the video it made it rock steady in the air. It seemed to fly more like you'd expect a TRex to.
MA
Here is the video
www.helidirect.com/videos/bladecp-belt1.WMV
www.helidirect.com/videos/bladecp-belt2.WMV
We are working on some more to make it much better for 3D.
Steve
Steve
how about the blade cp pro thats just coming out... im pretty sure it's just about the same frame, but upgraded to bell-hiller head and symmetrical blades, 370 main motor etc...
would it be compatible, do you guys know?
if so, i'd be very interested, would seem alittle easier platform to work off of than the "old" cp... just a thought
CA
I ordered the belt drive, thinking about a brushless motor, do I have to replace the 4in1 or can you tell me how it will control the 4th servo that controls the tail rotor?? if i have to replace what would be a good gyro,,. I have a JR 6102 if i have to go separate, i think it will work.. thanks
MI
Steve, a couple of quick questions, what is your set-up? I see you are running a Gyro. Are you also using a brushless set-up? Is this the Pro or a totally revamped CP. It looks great flying, far above the stock Blade. What $ would it take to get mine to fly like yours?
So, how much would it cost to upgrade a Blade CP pro to a belt drive and CNC head? What about the extra servo?
I am new to this, but I am learning. I am having to replace parts and don't know if I should be replacing them with better parts than just stock ones....
Jon
Jon
MA
- 55usd belt drive and frame
- main shaft, main gear, landing gear - 19.99
- plastic tail 15usd
- cnc head 110usd
for electronics
- if you don't want to go total separate
* you can use powerzone board (coming soon) with brushless motor and esc. You can use stock tx, 4-in-1.
you need a new tail servo, you can use stock cyclic servos.
- if you want to go total brushless
* you can use new gyro, esc, brushless motor and a new receiver and a new tx.
Steve
MA
- Gyro: HDX gyro (can use telebee, align gyro, gy401, gy240)
- ESC: castle creation 25A (can use any esc from 18A to 25A)
- brushless motor 400DH (i have HDX brushless 3800kv 24.99usd)
- receiver: Electron 6
- Servos hitec HS55 x 3 for cyclic, HS50 for tail (can use stock servos for cyclic)
- Battery: Apex 1350mAH (can use Epower 1300mAH, thunder power 1350mAH)
Strongly recommend for brushless set up.
Steve
MA
i have an eflite park370 brushless motor i just purchased and was wondering if that motor is good enough for the belt drive????
Steve
MA
Gyro: HDX head lock gyro, telebee gyro, gy401, gy240.
Steve
MA
some pictures with the new HDX300 fully bling, this is a custom built machine by JEFF
Note: for tail boom support, we have it coming soon. You can use trex boom support and cut down a little bit.
Steve
Steve
