E-FLITE BLADE CP PRO
#1852
RE: E-FLITE BLADE CP PRO
What is the standard NORMAL pitch curve? I have played with mine a bit and want to double check the setting.
I have
L = 38
2 = 43
3 = 50
4 = 75
H = 100
sc
I have
L = 38
2 = 43
3 = 50
4 = 75
H = 100
sc
#1853
I don't know if my option of Optic 6 wil help you, but anyway...
Normal:
PC , ThC
1: 25 , 0
2: 40 , 35
3: 60 , 65
4: 84 , 85
5: 100 , 100
Idle 1:
1: 0 , 100
2: 27 , 95
3: 55 , 80
4: 82 , 95
5: 100 , 100
Idle 2:
1: 0 , 100
2: 25 , 100
3: 50 , 100
4: 75 , 100
5: 100 , 100
Normal:
PC , ThC
1: 25 , 0
2: 40 , 35
3: 60 , 65
4: 84 , 85
5: 100 , 100
Idle 1:
1: 0 , 100
2: 27 , 95
3: 55 , 80
4: 82 , 95
5: 100 , 100
Idle 2:
1: 0 , 100
2: 25 , 100
3: 50 , 100
4: 75 , 100
5: 100 , 100
#1856
My Feedback: (10)
FL
Okay I replaced my stock blade grips when they broke with the Mico-heli aluminum ones. Now I can't get any lift whether I have 0 pitch or positive pitch, yet if I put the idle on, there is lift what gives? Did I put them on wrong somehow? Now when I move the right stick forward like I want to go fwd then it wants to lift. I set everything up like B-Davidson's guilde with the swashplate and pitch and everything but I get no lift. I double checked the radio settings to make sure I did not somehow change something on the setting but everything checks out. I am new to helo's so I don't know a whole lot here. Been trying to read the CP Pro thread but only have gotten so far. Anyone know? Thanks Gene
#1858
SC
hey all. i recently got back into helos. i have bcpp and i am not sure it its true but i heard that if you use the eflite gyro with the brushless setup that they will interfere. is that true?
#1860
I don't have blade anymore, but as I remember (I hope it's true, because I can't check it now...) red and green blinking means Rx isn't recieving signal (Tx switched off, Idle up on (plus Tx can't transmit when switched on while idle is up), damaged antenna,...)
Good luck
Kryso
Good luck
Kryso
#1861
SC
okay im doing a project for school that requires a camera mounted on my bcpp. i have added the payload up to be around 8oz. with the blade handle that for a brief 3-5 minutes at most?
#1862
PA
[8D][img][/img] Does anyone know if I can upgrde my lipo batt. to get more flight time? If so, what size should i go up to for the cp pro? thanks...Rich
#1863
I got a Mega Power 15c 11.1v 1350mah at my local hobby Town for around 29.00 for my cpp and get a few more minutes time with it . Its a little bigger but fits ok .
Carl
Carl
#1865
MO
I am having a glitching issue with my BCPP. For some reason, it seems worse when I move cyclic to the right, however it is not isolated to this movement. I assume this is a reciever issue or a transmitter issue??? Any suggestions.
Happy Flying
Happy Flying
#1866
AB, CANADA
Hey i got my blade cp pro a few days ago but now it doesnt want to turn off so i have to unplug the battery. does anyone know why?
#1868
AB, CANADA
Ya the blades are still moving at about half throttle when i unplug it. and the throttle stick is all the way down i have checked the reverse swith and power slider.
#1870
AB, CANADA
yes throttle trim to the bottom and and throttle should be at 0%, when i flick the idle up switch both ways and still doesnt do anything.
