E-Flite Blade CX2 Rotor Blade Replacement
Specifically,
How do you remove old upper and lower rotor blades and replace with new ones ? Is there a trick to doing these to get them in exactly the same configuration as the ones you've removed ? Do all new blades on this helicopter have to be balanced before they will work correctly ? Can't add balancing weights as in the real world, so how exactly can you balance these extremely light CX2 blades ? Also, with heatsink on the motors, should overheating be a problem while flying to where the heat may affect the control as the battery charge runs down ?
TX
RE: E-Flite Blade CX2 Rotor Blade Replacement
ORIGINAL: nasrr73
OH
I've never had to balance the CX blades from the factory, I'm sure I could have, but I never have. They've been fine.
Most people just use tracking tape or even packing tape for balance.
Just saying it's good to learn to balance straight up from the start but you really don't have to on these small Co-ax counter-rotating ones. Tis good training to do this for the bigger birds once you're ready.
Dy
Dy
CO
I found balancing the blades before installing them makes a big difference. With balanced blades my CX2 hovers in place like a dream.
Also I've found that yes, heat effects control. During a long flight my trim tabs can move from one side of neutral to the other. I try to cool down at the halfway point of a battery, around min. 5-6.
TX
ORIGINAL: Wolfpackin
Yo Bum...hot up there in McKinny?....sure hot an muggy here in Houston....
quick question about the 180 Motors...do they work well with the stock
Eflite batteries or do you need more powerful batteries?...and if so,
what more powerful batterry do you recommned?..thanks, John H., Houston
TX
ORIGINAL: jmhh
The stock battery works just fine with the new motors; I haven't noticed any loss in flight time per charge. I wouldn't have expected a degradation because the motors turn more freely than the stock motors due to the ball bearings, which would translate to more torque with the same amount of electrical current. I kept a watchful eye on the 4-in-1's green/red LED during my first couple of packs and it stayed green even when climbing at a pretty decent rate...until the battery got low on charge, that is.
After a couple of days of use thus far, I would strongly recommend the upgrade to anyone. I get better altitude control and much better tail stability (the rudder trim doesn't drift throughout an entire pack). The two extra batteries I have are DN Power 900 mAh vs. the E-Flite's 800 mAh, but all three of my batteries are rated at the same discharge rate: 10C.
Something else that has really helped me with controlling altitude is eliminating the ratcheting of the throttle stick. I opened up the back of the TX and flipped over the metal strip responsible for the ratcheting, which makes the throttle smooth throughout it's entire range.
