CP Pro twitching
GA
CP Pro twitching
I am having an issue with my CP Pro that I was wondering if someone may know why. The best way I can describe it is a twitch. When you are in a hover and move the cyclic to the right it seems to twitch and move harder than commanded. It moves fine to the left. I noticed the flybar paddles were slightly misaligned and I corrected them as best I could by eyesight and it got better, but not completely. I held it up to eye level and when you move the cyclic to the left it is smooth. When you apply right cyclic you can see the servo move and jerk, it doesn't seem to return to center without opposite cyclic. I am wondering if the servo is going bad or something else. Any suggestions would be appreciated. Thanks.
Will
Will
RE: CP Pro twitching
Unplug your motors from the 4 in 1 and all the servos except the one you think is going bad. Test it in a different servo slot and see if it still twitches.if so, its the servo.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
GA
Thank you for the information, I will swap the servos and see what happens. That seems to be the easiest thing to try first. Thanks again for the help.
Will
Will
yeah, I am having the same problemo =)
I'm upgrading to hs55's here as soon as they arrive. The s75 servo's really aren't all that good of a servo from what I have been told, the hs55's are supposed to be alot better and cost the same money. I got a replacement set of 3 hs 55's for 37 bucks with shipping.
