If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 15 of 15 FirstFirst ... 5131415
Results 351 to 363 of 363
  1. #351
    Join Date
    Jan 2008
    Moon Township, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Blade 400 - Tips, tricks, and mods
    If it is the stock servo it says in the book not to have the gyro in digital mode.
    I forget why but it could burn out the servo. The stock servo is digital but not
    designed to accept a pulse rate of 275hz. Page 26 on the owners book.
    Clames it will burn out the servo within a few minutes. I put on a Spektrum DSP75
    so I could run it in digital plus I got the DSP programer to set it to heli and tail
    and reverse it.
    MCX CX2 CPP B400 Trex 500 DX6i
    Hyperion EOS 0606i AC/DC Carl
  2. #352
    Join Date
    Jan 2007
    Cabot, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    just got the DSP75 servo for my B400 and just wanted to kmow if there is anything i should know before flying.
  3. #353
    Join Date
    Mar 2008
    south plainfield, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    some tips....if you change out or replace any servos or your gyro they will in most cases be reversed from what came out... you will need to check your controls and reverse their settings in the tx. if you are replacing your gyro with a different brand....some newer gyros require the tail to be setup mechanically to hover without drift in rate mode before switching to hh mode....no subtrim can be used! from experience your tail slider would be almost all the way over to the one side...you end up with poor resoultion to one side and smooth resolution to the other...ideal setup would have tail slider centered on shaft with aprox 8 degrees of pitch on the tail rotors... i emailed horizon hobby about this as i believe this is a flaw in their design of the blade400....i gave them a few suggestions but anyway they now have a speed up pulley drive for sale...it has an extra tooth on it that speeds up the tail rotor. im going to order one and try it... maybe i can get the tail slider somewhere near the center of the shaft on the mechanical setup...im using the hitec hg5000 gyro and tail servo combo but this setup is being used by many newer gyros also.
  4. #354
    Join Date
    Jan 2007
    Cabot, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the tips, i heard that when you are using HH that you are not supposed to use any rudder trim, is that true? My B400 drifts to the left even after setting everything just right, but after adding just a little trim adjustment, it's just fine. Now for that spin-up gear, what needs to be done to install that. I have looked over my heli and from what i can see is that it needs to be stripped down to repalce that little part. Is that so? Is there any vids, instructions on how to do that? Even though i am in the Air Force and i am a acft mech, I still need to see how its done ever once in a while. Just done want to mess anything up.
    Johnnie
  5. #355
    jp473's Avatar
    Join Date
    Feb 2008
    Dallas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a B400. Had it for almost a year. Got a metal head for it at Christmas. Took some doing but eventually got everything to work. On the original head assembly when the swash plate moved down the main rotors increased in pitch and when up a decrease in pitch. The new head assembly looks like it is of a trex design. The only real noticeable major deference being the actual swash plate servo link ball locations. Hard to explain with out pictures and arrows and a paragraph on the back explaining what each one was… (Sorry for that flash back. LOL) Any way, the first few flights went so well I thought I was flying a trex. No more slop in the head. So steady and responsive. I was very impressed! Until yesterday. I was fine tuning the main rotor tracking and making a very minor tail servo linkage adjustment. Now, no matter what I do or how I readjust things the tail has a right/left horizontal wag. Increasing the gyro gain speeds this wag up and decreasing the gain slows it down but no amount of adjustment seems to eliminate it. It happens in rate mode as well as heading hold settings. Any ideas on this?
    Gravity works, now overcome it!
    JP
  6. #356
    Join Date
    May 2007
    spring, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    so did you get the eflite head or the copter x head and maybe its your servo
    Evan
    hopped up blade 400 hs65mg\'\'s-cyclic/1/16 Mini E-Revo/hopped up jato 3.3/hopped up t-maxx/shockwave 36.....
  7. #357
    jp473's Avatar
    Join Date
    Feb 2008
    Dallas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Replaced tail servo with a new HS 65. The head is fine. Its the tail I cant stop from waging no mater how I set the gain.
    JP
  8. #358
    DeUglyOne's Avatar
    Join Date
    Jan 2009
    Grandview Plaza, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have you tried mounting the ball in one hole on the servo arm? Sounds as if the gyro is over compensating with the faster servo and the shorter rod travel may fix that.
    ** Old enough to know better **
    ** Young enough to enjoy it **
  9. #359
    jp473's Avatar
    Join Date
    Feb 2008
    Dallas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bought a new gyro and you know what? Still had the same problem. [sm=48_48.gif] Now I’m pissed and 64+$ lighter. Started checking everything again starting with the tail. Can you spell D a a a a?[sm=bananahead.gif] Found the answer to the 64 dollar question. Had a slightly out of line tail rotor feathering coupling causing the pitch to osculate ever so slightly. Throw in a gyro trying its best to keep things at a given point and you get a waging tail not related to a gain setting.[sm=49_49.gif]
    Guess you could say the tail was waging the dog.[sm=spinnyeyes.gif]
    JP
  10. #360
    Join Date
    Sep 2006
    lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well one good thing is u have a back up gyro. that sure does suck when you replace things and dont get any closer to a solution to your problem. I've done it ALOT. Glad to hear the problems solved at least.
  11. #361
    jp473's Avatar
    Join Date
    Feb 2008
    Dallas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And a backup servo. . . . getting closer and closer to having that next helli.
    JP
  12. #362
    Join Date
    Oct 2008
    Rio Linda, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I m wanting to upgrade my gyro what would be the best choice. I have heard good things about the futuba 401 is that the best bet or is there something better. Thanks
  13. #363
    Join Date
    Apr 2009
    Sioux Falls, SD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bump just need to find this again
    Hobbit
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
