Xtreme aluminum flybar center issues on CX2
ON, CANADA
Hello All,
I just got the Xtreme aluminum center hub so I could go with the 1.5mm carbon fiber rods as flybars. BUT the hub isn't fitting into the E-flite aluminum flybar holder. its sticky and the cap won't go on all the way.
Anyone else have this issue? I'm sure I could sand/cut it down till it fits, but I thought this mod just pops in...
WI
RE: Xtreme aluminum flybar center issues on CX2
If you play with the orentation when you put it in it will fit. You need to drop it in with the little nube up and down then rotate once inside so they face out the sides. mine will not drop in unless i turn it but once in place and tightned down it is nice and free. I hope this works it is a great modd and i would never go back to the steel fly bar.
Scott
Scott
