CP Pro DX7 PITCH CURVE NEEDED HELP!
Anyone have a great set up for the DX7 radio and its pitch curve for a CP Pro. All setting would be great if you have them for the cCP Pro. Great, if you have all settings for the CP Pro and DX7. email [email protected] THANKS Ron
NE
RE: CP Pro DX7 PITCH CURVE NEEDED HELP!
You can use this pitch curve on any helicopter.
Normal
1: what ever value will get you around -1 to -3 degrees of pitch
2: in between 1 and 3
3: 50
4: 75
H: 100
ST-1
1: 0
2: 25
3: 50
4: 75
H: 100
Normal
3: 50
4: 75
H: 100
ST-1
1: 0
2: 25
3: 50
4: 75
H: 100
NE
If you have a pitch gauge move the collective down until you get -1 to -3 degrees. Then it should tell you on the graph were that is at. Then two is in between that and 50. Or you could start at 47 for 1 and see how you think about that setting. Somewhere around there should be a good setting.
