CP Pro info. 3 in one QUESTION? Help!
How does the light light up on your 3 in 1. Is it always Red? Always Green. Trying to solve something. Green to red? When does the colors change? Thanks Ron
CA
RE: CP Pro info. 3 in one QUESTION? Help!
I think during initialization it blinks red, then blinks green. When it's done initializing it's solid green unless it's at full throttle (in the ESC, not necessarily full stick) and then it's solid red.
Mine lights green and stays green until I reach about 1/2 throttle and it lifts off the ground. As soon as it comes off the ground it turns red and stays red for the remainder of the flight even if its just a 2 foot hover. I thought this use to say green until you were heavy on the trottle or battery was low.
