BATTERY FIX ! How To Rebalance Lipo's
Success! Well so far.
I figured out a way to rebalance your 2s batteries without the need to buy expensive chargers. I’m not sure if this has already been done but I did several searches on google/yahoo/forums and came up with nothing.
I’ve been flying with my two stock e-flite batteries for months now and have about 200-300 flights through them using only the E-Flite and Venom charger/balancer. I used to average about 8-9 minutes of flight per battery until just this week when I started to notice my flights dropped down to 5-6 minutes. So I took out my Volt meter and checked each cell, sure enough the cells were unbalanced on a full charge. One cell read just below 4v’s and the other was at 4.2v’s.
I spent a whole day trying to get them rebalanced with the chargers by unplugging and replugging them in, I even slightly drained them and tried milking the charger but they won’t level out. So this is what I ended up doing and testing,
1. Tested each cell on a full charge with a volt meter
2. Plug a 5v LED light onto the stronger of the two cells (needs to be at least 5v LED, anything else will fry. I think blue LED’s can handle higher voltage)
3. Let it drain that cell for about ……….5 hours (every 20-30 minutes check on it with your volt meter)
4. Once the cell has level out even with the other, then just recharge it on your charger. It should now charge balanced.
I still haven’t figured out the long term affects and have only tested it twice. I’m getting my full 8-9 minute flights back and the cells seem to be keeping balanced after each dis/recharge. I’ll see how long it last, and hope others will assist me in this testing and keep everyone posted on it.
Please look closely at the pictures below and take note on all the arrows to see how to test each cell.
IN
RE: Battery FIX! How To Rebalance Lipo's
I still think that eat2muchrice is a goofy name. But you seem to be nearly brilliant, so I suppose I can't pick on you too much. That was a really good idea - and simply brilliant in it's simplicity!
Good work. The Collective thanks you.
Soloboss
Soloboss
Well..........put a DVM on my offending lipos as well as me good DN's and found that oddly enough they measure the same (basically) hmmmmm......now keep in mind DVM's as nifty as they are do not put any kind of "load" on the thing that is being measured. Whereas the old school analog meters do. Me thinks I will follow this further as the batts die. Good work and direction!
Rikybob
Rikybob
Its the Collective that the thanks should go to. Just 5 months ago I didn't know cr@p about anything dealing with rc helicopters, I didn't even know what a balance plug was . It was everyone in this forum that has tought me the ways of the heliforce.
Its slightly insidious. Much like one would imagine a heroin addiction would be. I see therepy in my future
Now you have to excuse me. I have to go stare at the Esky forums at the single rotors. Help!
Rikybob
Rikybob
CA
ORIGINAL: eat2muchrice
http://led.linear1.org/myth-of-the-5-volt-led/
LED's should always have a resistor in series, whether it be internal (rare for the type of LED you seem to be using) or external.
How do you ck the ballance on a 2cell and a 3 cell lipo. I have a volt meter buy dont know what leads to but the red and black wires to . I use it on the end that plugs into the hile to see if it is fulley charged or how much it is discharged. I guess you use the white plug that goes into yhe charger buy what wires do you use, on the 3cell i have a black yellow blue and red. and on the 2cell i have a black abd two red on the white plug.
Carl
Carl
I think I figured it out. on the two cell my 3 Mega Power 4.15-4.17 next two 4.20-4.22 the 2 cell E-flite reads 4.02-4.01
My e-flite 3 cell 4.15-4.16-4.16
I use the e-flite charger that came with the CX2 to charge the CX2 batterys and the CP Pro batterys.
Carl
Carl
ORIGINAL: gnd2
FYI
Does anyone have a recommendation as to when they would balance with this method? For instance, when one cell is +/- 0.1 volts different than the other? With the DVM my cells read 4.17 and 4.21 at full charge using eflite stock charger. Is this close enough?
eflitemaniac
eflitemaniac
ORIGINAL: eflitemaniac
eflitemaniac
eflitemaniac
One day I'll get a digital multimeter and you bet my batteries will be near perfect.
CA
Its a "expensive" cheap Radio Shack LED. They come without any resistors.
ORIGINAL: gnd2
FYI
Actually, if it really takes 5 hours or so just to "balance" out the cell, it must not be drawing that much current so maybe it's OK, but in generally you shouldn't use diodes without some series resistance.
CA
Lets just say I fired 3 different LED bulbs doing this test.
Or you could just get a blinky which will do the same thing for you automagically for only 25 bucks
ON, CANADA
RE: BATTERY FIX ! How To Rebalance Lipo's
This is what I use:
http://www.rctoys.com/rc-toys-and-pa...ERS-POWER.html
I originally purchased it for my TREX, and use it every time I charge (I have it plugged in as I'm charging)
It will auto balance the cells if they are more then 0.005V out (no, 0.005V isn't a typo)
By doing this you get the best possible charge and your lipos will last the longest.
Not a bid deal when you can get DN lipos for $15 for your CX2, but much more important when you're using $100 batteries that I have in my TREX...
hi.
I balanced mine using a computer fan with blue led lights.
It only took 10 mins to bring it from 4.23 down to 4.11
The question I would like to ask is after i flew my heli to flatten the battery ready for its charge I took another reading. insteasd of them being the same like you would expect, the red lead cell was 3.71 and the black lead cell was 3.49 why would they discharge differnt.?
Im going to charge it an see if it rebalances.
Will post back.
Will post back.
yes, using a computer fan would is more idea then my stupid LED and waisting 4-5 hours.
Did you recharge the battery after you balanced it? test and recharge it after you balance, then test it again after a discharge flight.
My batteries seem to discharge fine, but one cell losses power when i store it a couple of days.
Maybe one of your cells is starting to die and you just can't fix that....well not to my knowledge.
hello.
the 1st battery I equalled out then used, it now is not equal
The 2nd battery I equalled out then recharged and it is equal. need to fly then recheck.
Going to try redoing bat no.1 and see what happens when I charge after a equal....then a fly.if that makes sence?
fingers crossed.
fingers crossed.
ORIGINAL: Phill86
hello.
fingers crossed.
hello.
fingers crossed.
I would be interested to see how the balance is after you do this, balance first, charge, then check balance again to see if charger could not keep balance when charging
After the balance and charge both batteries are fine. all equal.
When I have used them neither battery is equal. maybe they are failing.
At least the charger is working ok, as it can charge them equal.
Going to try re balancing again just to make sure.
Could the motors be failing as it is always the same cell that is lower. (red lead on both batteries)
Would a failing motor just not work or do then slowly fail?
It depends really on what part of the motor is failing, ie stator etc
The current draw should increase as a motor starts failing, the power will decrease noticably as well, which might knock battery cells out of balance.
