Brand new Blade 400 smokes and stops working
FL
I just got my Blade 400 today. Connected a charged batter to test servo throws and radio functions. Spun it up a little (not enough to lift off) and flipped one of the switches on the radio and thing began to spew white smoke from the ESC. Now it doesn't work at all. I waited 4 months to get this thing and now, within 60 seconds of powering up, it's dead. Servos work, but the motor just quivers and the blades don't spin. What are my options? Anyone have anything like this happen to them? I hate the idea that I may have to spend more money to ship this thing back.
RE: Brand new Blade 400 smokes and stops working
Oh well live and learn...
Sorry to hear about your problem. I feel your pain. I would call horizon hobby to see what they can do..
AB, CANADA
ORIGINAL: BaracW
ORIGINAL: BaracW
You have an expensive way of learing how things work. You'd think in the 4 months you spent waiting for the thing to show up you could have downloaded the manual. Live and learn.
FL
Barac, You know expression that these things run on the magic smoke. It must be true because once you let the smoke out, they don't run any more. Unfortunately, you have just learned one of the expensive, VERY fast, irreversible lessons of all things electric. If you flipped a switch to see what it does, you could have easily gone from regular control to idle up mode without the blades spinning and overloaded the circuit. Did you notice that the blades kind of rotated down at teh same time? Horizon is remarkable good about fixing things even if it is our own screwups lots of times. Hard to say what they may or may not do. Harsh, but everybody on here is right, you do have to know what all of the switches and adjustment do. You didn't say what your level of experience is, but the B400 is definitely not a beginners machine. Good luck, Doc
Bummer Man! Can't agree more with the "Read the Manual" comments however. More than half of the questions posted on this forum could be eliminated if people would open/download and read the frick'n manuals. Hope you learned your lesson and get a flying bird soon.
Be carefull with that magic smoke...
FL
Guys, I read the manual and knew what the switch was for. I was testing the function of the switch. I must admit, I was not at full throttle, but I was not at idle neither. Perhaps, it was slower RPM's than suggested, but I noticed the increasing speed and flip the switch back. Anyway, lesson learned. If it costs me $40 to replace, it will be the last $40 bucks I spend on the same part for the same reason. Hopefully, HH will have mercey. I am not a beginner, but I am not an expert. I have flown Blade CX, and hovered Blade CP Pro and Axe CP.
Just buy a new ESC - this will not be that last $50 bucks yop spend on this heli. The rule of thumb is that you will spend as much on replacement parts as you didi on the original heli......
Okay, sorry to throw you in with all those other knuckle heads.[&o] Probally just a bad motor or whatever... Good Luck!!
ORIGINAL: BaracW
Guys, I read the manual and new what the switch was for. I was testing the function of the switch. I must admit, I was not at full throttle, but I was not at idle neither. Perhaps, it was slower RPM's than suggested, but I noticed the increasing speed and flip the switch back. Anyway, lesson learned. If it costs me $40 to replace, it will be the last $40 bucks I spend on the same part for the same reason. Hopefully, HH will have mercey. I am not a beginner, but I am not an expert. I have flown Blade CX, and hovered Blade CP Pro and Axe CP.
My Feedback: (15)
IL
If the blades were spining, switching to idle up should not blow your ESC.(strip gears yes....) There were many times with my Rex I kept the heli on the ground at zero pitch (70% throttle) and flipped to idle up (95% throttle) for a quick take off burst. I would work on auto's with no power and chicken out and hammer the throttle with no problems also. The tail would kick out, but never ESC issues.
The gyro was a CC35, but that should not make a difference.
Call Horizon (Corey seems good to deal with).
It may also be the motor, I would send both back.
Good luck
Good luck
