Blade CP, No Lift, Installed Super Skids???
I bought a used Blade CP, installed Super Skids, tried to fly and got no lift off. It seems to really want to lift off and gets really lite on the skids but just won't lift. I have taken the heli apart, leveled the swash, blades seem to be tracking. I am using stock battery. Could the Super Skids be causing my problem because of an increase in weight. Would upgrading to motor w/8tooth pinion and 3 cell lipo remedy my situation? Thanks for any help.....
RE: Blade CP, No Lift, Installed Super Skids???
Try turning in all 3 cyclic servo links 1 turn and then try to fly again. You may need to add a little pitch to get it to lift off.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
