CX2 Crash
CA
CX2 Crash
I decided to take my CX2 outside for a flight yesterday, but during flight the wind caught it and started to carry it away, before I knew what was happening it was a couple hundred feet in the air and a couple hundred feet away. I decided as it was approaching a crowded parking lot, knowing it was un-recoverable, I decided to kill the power before it made it over the parking lot and hurt someone. I ended up damaging the Battery & Battery Holder, Outer Shaft, Inner shaft, Flybar, Upper and Lower Blades, Lower Rotor Head, and the outter canopy was a complete loss. The heatsink was dented, and the 4-1 controller had a small dent in it (circuit board looks undamaged).
I ended up with some major damage, but have since replaced all damaged parts, with new parts. However, after I replaced the parts I took it into my living room to test fly it and now it is all over the place. I tried adjusting the pots, and attempted to re-trim the remote, but evertime it takes off I can barely control it. I tried the "Support by flybar" trick to make sure it was balanced, and it is, and I never had trouble before this happened. So any help or suggestions would be appreciated.
RE: CX2 Crash
Have you checked yur servos to see if they have been stripped in any way ?
I take it the swashplate was already levelled out
If its that uncontrollable i would think servo problem or maybe gyro bust
CA
RE: CX2 Crash
Well before it crashed, I had replaced the plastic swashplate with an aluminum one, which appears to be unbent or broken, which is why I didn't replace it. I did try to level the swashplate as best as I could, but it still seems to be having some issues. It could be I'm just not leveling it good enough, is there a trick to this? If the gyro is bad, is there an easy way to check?
RE: CX2 Crash
Have you read this? It will help you get your swash level.
Swashplate Leveling Guide
http://www.rcgroups.com/forums/showthread.php?t=642401
CA
RE: CX2 Crash
Thanks for link, it turns out it WAS the swashplate, as it wasnt really level, which really helped me dial in the elevator and alieron trim. I am still getting a pretty good left hand yaw, even with the pots all the way counter-clockwise and my trim set full left, but it is managable.
RE: CX2 Crash
ORIGINAL: rasjax
If you want to try and fine tune it then read these links.
Gear Mesh Guide
http://www.rcheli411.com/pages/howto.php?howto=7&page=2
Bents Shaft Repair
http://www.rcuniverse.com/forum/m_6791546/tm.htm
Dacaur’s Guide
http://www.dacaur.com/bladecxhelp.html
Eat2muchrice’s Warped blade test
http://youtube.com/watch?v=_7PwNTXOWMs
Eat2muchrice’s Blade boil fix
http://youtube.com/watch?v=RmNv8OlG6GQ
