CX2 Blade Grip Upgrade Help
CO
As I view the options available I get more confused [], so can someone tell me what is best.
Xtreme CNC Blade Grips w/ Blades or Microheli CNC Blade Grips w/ Exxtreme Blades ( I beleive I saw 2 different types of CNC Grips they sell)
Then there is also the Microheli Exxtreme Core V.2.0 which looks to be plastic ?
All Microheli I believe are Folding blade type, HELP ! What is better, more durable, or any other input you could provide based on your experience.
RE: CX2 Blade Grip Upgrade Help
I don't have any of the above but everything points me in the direction of keepin' me stock stix! Mine perform admirly and it seems to me that unless you just want the bling, just replace the other parts that seem to break more............like the lower rotor.........just me 2 cents..............good luck on whatever endeavor you choose!
Rikybob
Rikybob
NE
Don't buy that plastic one from the extreme core. The parts are from the Dynam Vortex. It will cost a 1/4-1/2 price buying the Vortex parts compared to the cost of the extreme core.
NC
anybody know how the Xtreme Alum. Blade grip combo. from Boomtown hobbies $43 works with the aluminum EFlight heads , Eflight aluminum swashplate, short flybar and stock shafts? I've heard boomtown service is great. thanks
NE
I haven't tried it with the aluminum upper head, but it works fine with the stock shafts, E-flite aluminum swashplate, and E-flite aluminum lower rotor head.
ORIGINAL: weare5
The 3rd one with the shafts is the best one. But buy it with the everything, mine flies so much better and stronger.
If it works for you then I say good for ya but I got the same parts for 15 bucks shipped to my door.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
I've been eyeing the first one (new micro heli's grips) for months, they weigh only 3....somthing grams. My biggest problem is forking over $60 for them. If you decide to get them please please do a review on the forums for us.
I've also tried just the plastic grips on the 3rd picture (extreme) without much luck.(sent them back), But have heard the whole core is better. Try arrows idea.
WI
I have the second from the left and have not been happy with them. They required sanding of small spacers before they would fit with out binding, and I have had TBE since I installed them. I would go with the on the right.
QC, CANADA
ORIGINAL: evdreamer
www.bladecx2.com
getting very tire of peoples that said our parts are vortex
before making comment on something be sure to verifiled what you said
is this clear or not
Sonny Lambert
President of bladecx2.com
I've fitted the extreme core grip blades. Now I cant seem to stop my heli moving in a clockwise 5ft circle. The nose stay pointing forward. it cant be the trim as on its journey its moving backwards and forwards if you see what I mean. Any Idears. What does the fly bar do??.
QC, CANADA
NOT SUR ABOUT THAT......WATCH IT!!!!!
[link=http://bladecxpro.spaces.live.com/blog/cns!6143F654C8C0E53D!1453.entry]BLADECX2.COM[/link]
AB, CANADA
rc4 I've been flying the Xtreme blades, grips, Eflite CNC upper hub, swash plate and micro heli CNC lower hub for almost a year now. Great stuff you'll have now problems at all. It does take a bit to get her trimmed right but once you get it you won't ever go back to stock.
