cx2 battery help
CA
cx2 battery help
i have 5 batteries for my cx2 that sat for a couple of months during
the rain and cold fully charged.
i went to fly my heli so i put 2 of my batteries on charge
then went to fly only to find out that the battery would only give my heli
lift for about 3-4 min
they are all pretty new, with only 10 flights in them
how do you bring them back to life??????
or are they toast????
some are e-flight , common sence, smc batteries
thanx
thanx
RE: cx2 battery help
Try this out.
Cheap Battery Test and Fix
http://www.rcuniverse.com/forum/m_6970199/tm.htm
Note: Use a computer fan to drain the cell.
Did the "ice" charger work?
You can restore your batteries.
I have 4 batteries since last Nov. Two of them are E-flite. I only have an E-flite charger with CX2. I do not have this problem.
1. You may have a problem charge. It did not change up to full.
2. You may run the bettery too low before you charge.
