blade cx range problem
hey guys i have a blade cx ever sence i got it its had bad range like 30ft is max if you go out of that box she'll drop like a rock . and if you hold the radio down its even worse . it has a new 4in 1 and cystal set .im thanking theres something wrong with the radio . any help would be great .
RE: blade cx range problem
ORIGINAL: DRAGONFIRE81M
IN
You may try replacing the crystals. Enen though you got new ones one may be damaged in the package. Also sound liky you could have a problem with your antena. Check that over real good and make sure it's not damaged somehow. Could have one or both bad. I fly CX2 with 2.4 so I never had that problem but I also have a Falcon 40 on stock fm radio gear and there is definately a limit to how far I can go.
thanks guys . i replaced the 4in1 . i thought was going to be the fix but didnt but after doing that i had no radio signal so i replaced the crystel that fix that but it didnt help the range . also have good new batterys for both the heli and tx . im going to asy my lhs who i got it used from if i can use a nother radio to see if thats it . the only thing on the 4in 1 are pots for the counter rotason
