part numbers for bearings B400
Hi.
I would like to make up a spare head for my B400 ,but I cannot find a part number for the bearings that go inside the flybar control arm set and the head block.
Does anyone know what part numbers these are, and also can you get an all alloy swashplate?
thanks
thanks
NE
RE: part numbers for bearings B400
I tried looking at the online manual and they didn't have a number by it. But the manual listed the bearing sizes and part numbers. For Example 2x3x2.5. The first number should be the interior diameter, the second the exterior diameter, then the third the depth. You could try measuring the bearing and see if it is listed. By the way it is in millimeters. Here is a link to the swashplate http://www.e-fliterc.com/Products/De...odID=EFLH1433A I think it comes out in June.
Nick
Nick
Thanks evdreamer, I will get out the tape measure.
[sm=thumbs_up.gif] for the link to the swashplate, will wait I think and get that one.
NE
Your welcome. I must have been thinking about another part that came out in june the swashplate comes out in mid august. http://www.horizonhobby.com/Products...odID=EFLH1433A
Nick
Nick
Incase anyone wanted to make up a spare head, I thought I'd post my findings on the bearings.
I got the Align bearings part number HS1033 also known as MR52ZZ. or Eflite EFLH1466 2x5x2.5
Align was much cheaper. These bearings go in the Flybar Paddle Control Frame Set: EFLH1424.
The other bearings for the Head Block/Rotor Housing Set: 3x6x2.5mm EFLH1115
Hope someone finds this helpful.
