Blade 400 Moter wires
Putting together my ARF B400. I got the motor today and not sure how the wires go. Looks like they go out the front and on the right side Is this the way they come RTF. Also looks like its going to fun pluging in the ESC when it comes tomorrow. How does that go or should I have pluged them in before I put the motor, in looks like they will be hard to hold onto and plug into the esc since they are under the frame. Mabey there is some trick to this.
Carl
Carl
GA
RE: Blade 400 Moter wires
Having spent a lot of time swapping ESCs between two B400s, I can tell you how I do it. I have a small needle nose plyer that I hold the recepticle with while pushing the plug in with my fingers. I can get a hold of the recepticle through the frame. I also use the same method to disconnect, so as not to stress the wiring.
