mCX USB Charger
mCX USB Charger
The first boards for my new mCX USB charger showed up while I was away for Thanksgiving. I got back today to find them waiting on me.
After building up a couple test units, I managed to charge and run through about 4 cycles with my standard mCX batteries. The charge time is a little slow (~55 minutes for me) but that is mainly due to the fact that the USB port of a computer only supplies +5VDC and the LiPo charging controller is limited to 100mA when using USB power.
The charger is pretty simple. Plug into a USB port of a computer, plug the other end into the charger and then plug in the battery. The STAT LED will light to show charging and then go out when charging is complete.
Here is a picture of one unit charging a battery:
I plan to have these available for sale possibly this week. The charger will come assembled with a heat-shrinked covering. I will offer the charger with and without a 24" USB A to Mini B cable. I have not set prices yet.
IN
RE: mCX USB Charger
KE4NYV.
Excellent, I like that idea. Even though a tad slow in charging. With multiple USB ports you could charge a host of batteries.
Questions, where did you get the charger and may I also ask the price?
Thanks in advance,
Dave
Thanks in advance,
Dave
RE: mCX USB Charger
ORIGINAL: choppersrule
RE: mCX USB Charger
Just an update. I have successfully used one of my Garmin GPS USB chargers that plug into an AC socket to power the USB charging board and charge two batteries. I also tested my TomTom charger just for some variety.
This should work with just about any AC USB charger for the numerous devices that use this connector for charging. The USB standard is for +5VDC and the pin is standard, so they should all work.
One thing I have not tested yet is one of those Belkin lighter plug USB adapters. These are basically a lighter plug with a female USB A socket that will accept the USB A to Mini B cable. I expect it to work, but I would like to test this first before I give it the thumbs up.
IN
RE: mCX USB Charger
KE4NYV,
Keep us posted on the progress, another very interesting project you have going on. Post pictures when you have the time.
Dave
Dave
ORIGINAL: KE4NYV
RE: mCX USB Charger
At this point, I have two products in the works:
1. mCX Single Cell USB Charger
2. mCX Four Port DC Powered Charger
According to some discussion on other boards, it looks like my charger will work for the Vapor batteries as well.
RE: mCX USB Charger
KE4NYV - can you offer a version with a male USB port on one end that will plug directly into my computer's USB port and have the battery plug into the other side of the board? That way, no cable is needed... have the PCB just plug direclty into the USB port!
thoughts?
thoughts?
RE: mCX USB Charger
thoughts?
thoughts?
Yeah, I think that is a possibility, but the only problem I see is with the fact that it would stick out of the computer about 4" inches and increases the chance for it to be caught on clothes, hands, ect. and break the connectors off. I'll give it some thought and see if maybe I can some up with somthing a little better design-wise.
TX
RE: mCX USB Charger
Since the stock charger uses 6v to charge the batteries (four 1.5v AA batteries), I was hoping to find a way to make an adapter to use with my ICE charger. It is made to run on 12v DC power (I use a computer power supply when I'm near a plug), but if I can charge receiver batteries then I should be able to power the 6v charger and avoid using the AA battery set-up, right? My knowledge about such things is limited. []
Could you make an adapter for that application? I would be willing to buy one rather than test my own design.
RE: mCX USB Charger
If you can find the battery connector pigtail (PKZ3052) you could make a small haness that would plug directly into your charger. I plan to buy some of these chargers when done but also make up a few harnesses to use with my current chargers.
My Feedback: (7)
NY
RE: mCX USB Charger
The USB seems OK - but how about a charger for the MCX that has alligator clips to hook into a standard 12v output 0 could then work from any power source and might charge faster.
